April 17, 2014 6:09 AM PDT
if you notice your cylinders have steel inserts for torqueing the heads. spark plugs are steel so steel on steel is better. I've used heli-coils on many other things and always used thread lock to secure an insert, this is the first time, I know of, heli-coil said to use RTV instead of thread lock. kinda disappointed I went by the instructions instead of instinct. These actually say for aluminum heads. Maybe the expansion is the reason for RTV but I've used inserts in other aluminum parts before with locktite and never a problem I've never seen aluminum heli-coils through out the years I've seen lots of issues with spark plugs stripping aluminum heads not just HD but bikes and cars
